horslaloi Posted September 30, 2005 Share Posted September 30, 2005 Hi, This is actually my first post on this forum and also my first model of a house. The modelling was done autocad and rendered in 3ds max. This house is for a course that I am presently. And now I going to start texturing it So any comments?? Thanks Mike Link to comment Share on other sites More sharing options...
TheAllusionisst Posted October 1, 2005 Share Posted October 1, 2005 Nice modeling! If you change the 'facetres' number to a higher number like 4-8 before exporting, your arched window will be a smooth arch and not be faceted like it is now. You can play with the number something like 2 may do the trick and you will end up with a less dense mesh. Nice job! Link to comment Share on other sites More sharing options...
edub Posted October 3, 2005 Share Posted October 3, 2005 nice modeling. There's a weird line running across the roof of the porch. Also, you should break the phong shading on the same roof, so the edge shows up - right now it reads smooth (a result of the phong smoothing). Link to comment Share on other sites More sharing options...
vizwhiz Posted October 4, 2005 Share Posted October 4, 2005 Mike you can set the facetres variable in autocad to 4-5 or even higher and when filelinking (or are you importing?) you can set the acis deviation to 0.1 or even lower = 0.05 for smooth curves warning the File Size will go up but The end result will look nice and smooth hey make The computer work for a change ** great work especially for your 1st model in autocad Thanks Randy check out mental ray (eventually) much better Than radiosity for rendering Link to comment Share on other sites More sharing options...
