chow choppe Posted October 6, 2005 Share Posted October 6, 2005 Hi ...... i found sometime back overhere about how to make Maxstart.max and where to save it...Can't find any thread about it.. can someone tell me how can I save my settings and let it load automatically as default when i start max...I know thats done by maxstart.max but how Thnks Link to comment Share on other sites More sharing options...
jstar730 Posted October 6, 2005 Share Posted October 6, 2005 maxstart.max is found in your scenes folder. setup up everything from viewport, rendering, and whatever else you can think of then click file, save as, look for the file maxstart.max in your scenes folder and then click save. i am not sure if all your settings will be save but i'm sure most of them will be saved. hope this answers your query. jojo some of the settings that worked with my maxstart.max: perspective viewport is located at the upper righthand corner, color of my viewport background, safe frame is on, default renderer is vray, snap is on, resolution is set to 640x480 (can't remember the rest because my pc is rendering at the moment). i guess you just have to setup everything you can think of, save and check which settings were saved and which were not. Link to comment Share on other sites More sharing options...
Ray Posted October 6, 2005 Share Posted October 6, 2005 I think you can also redirect, via customize paths, to where your maxstart.max is located--in case you don't want it in the default location. Link to comment Share on other sites More sharing options...
chow choppe Posted October 6, 2005 Author Share Posted October 6, 2005 Thanks.....It worked Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted December 23, 2008 Share Posted December 23, 2008 Sweet, worked a treat. I was not getting joy from the help. "Do this." "OK." "Heehee." "Oi!" The web wins again! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted December 23, 2008 Share Posted December 23, 2008 (edited) Hmmm.... I remember seeing this on Vray's forum a couple of years ago, and always meant to go back and search for that thread, but I never did. So, thanks for the tip, ...but, I can't seem to get it to work. My scenes directory in my 3dsMax2009 folder is empty. I tried saving a file there called MaxStart.max to see if it automatically read it, but that didn't work. I should also note that I have my useUserProfile=0, which may effect how and where it Max for the MaxStart.max file. Edit: I figured it out. I have my MaxStart path remapped to a folder that contains UNC shortcuts on the server so I can quickly navigate to all of my projects. I dropped a copy of the MaxStart.max file in that directory. When I launched max, it launched normally, then quickly loaded that file. Edited December 23, 2008 by Crazy Homeless Guy Link to comment Share on other sites More sharing options...
redzuan3828 Posted December 24, 2008 Share Posted December 24, 2008 This issues look easy but it took a few day to fix it because I search by myself. I know how to do yesterday by try and error. Today I saw this topic in here.... hehe... Link to comment Share on other sites More sharing options...
