milky glass
mzex
hm
I tried that but i got this.
it seems that without translucency I get better result.
first two are without translucency (different settings), and third jpeg is with translucency. max file is file where you can see settings I use for third picture.
Well, with Vray, you're typically better off achieving translucency ( such as with frosted glass or milky glass as you had asked) by using refractive glossy properties and fog colouring, as opposed to the translucent checkout. The exact reason for this, I'm not exactly clear on, but it might have to do with the fact that translucency is not a straightforward thing that works the same for all materials.
In any case tips on how to use, adjust and know the properties of the refractive glossy properties, can be found at;
http://www.chaosgroup.com/stuff/MtlTutorial/
But personally I found this particular demosntration more informative and helpful in knowing what the effects would be:
http://www.richardrosenman.com/vray_absorption.htm
Just remember that you typically have to use the fog colour function as well or else you may not get the result you desire. Also remember that sometimes you can have translucency through a mapped material ( for example with a marble texture, so as to give the effect of alabaster like you have with lampshades), and usually all you need for that kind of transluceny is to use a fallof map in the refract map slot going from white to black ( or vice versa depending on from where you're looking) and adjust the curve to get the transparency you need. The diffrence between the 2 methods is that with glossy refractive translucency you get a blurry (gaussian) distortion of objects that are further away fromthe glass than those just next to it, but with a falloff map you get the kind of translucency you get when you look through a light cloth. Reading your post I assumed that you wanted to simulate the former hence the links to the absorption tutorials.
I hope this helps.....
imo it depends on what the glass is going on. hard to tell with these cubes. it doesn't look like reflection on the glass is important at all in this case. if i'm right, whynot just use a standard material, pick your color, desired opacity and give some illumination? it would sure save some rendering time.
