arquitaty Posted October 13, 2005 Share Posted October 13, 2005 Hi all! I am a sketchup beginner so I still a little lost. I watched all the get started tutorial but I still have many doubts. Someone knows f it is possible to get a tutorial that shows step by step how to create something and not only the tools which are available like in the get started tutorials? Thanks in advance Link to comment Share on other sites More sharing options...
AJLynn Posted October 13, 2005 Share Posted October 13, 2005 I think most people learn this by checking out all the tool then messing around, never used a real tutorial but Sketchup5 has the "Self-Paced Tutorials" in the help menu, and some people I worked with got a book called "The Sketchup Book" that they found useful. I found it very intuitive having experience in Max, Autocad and Illustrator. I generally begin by importing a CAD plan or an image to trace, then work from there using mostly pen and push/pull. (If you import CAD you'll probably have to get the enclosed parts that should be filled to fill by drawing over one of the lines.) Also, I don't know why @Last doesn't have keys assigned to most of the tools automatically, but it's a lot faster if you set some up - Window menu -> Preferences -> Shortcuts. I use a modified Adobe scheme like this: Line - P Arc - A Select - V Move - M Rotate - R Pan - Space Push/Pull - X (for eXtrude) Paint Bucket - G Remember that groups and components are important for various reasons - e.g., if you use the line tool to draw on a side of an object, you are adding to that object, maybe subdividing the face, etc, but if that object is in a group that you're not working inside you'll be drawing a new object but can still use the old one to snap. Link to comment Share on other sites More sharing options...
mauarduz Posted October 14, 2005 Share Posted October 14, 2005 taty, sketchup has many video tutorials on their web site Link to comment Share on other sites More sharing options...
STRAT Posted October 14, 2005 Share Posted October 14, 2005 yup, check out the sketchup web site and specifically their forums. they're a fantastic resource Link to comment Share on other sites More sharing options...
boucra Posted November 4, 2005 Share Posted November 4, 2005 Yes have a look by SketchUp.com and you will lern fast. and good. boucra Link to comment Share on other sites More sharing options...
