kraphik Posted October 13, 2005 Share Posted October 13, 2005 I load DXF file into C4D. I cannot see anything. What's the problem? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 13, 2005 Share Posted October 13, 2005 I load DXF file into C4D. I cannot see anything. What's the problem? Either the file was empty, or your viewport isn't pointing at it. There should be an object, or many objects, listed in the Object Manager. Select one, then hit the 'O' (capital letter O, not zero) to force the viewport to center on the object. You should see whatever was imported then. Link to comment Share on other sites More sharing options...
mike_sul Posted October 13, 2005 Share Posted October 13, 2005 Try saving the dxf files from autocad as version 12 dxf, version 14dxf and then try importing it into c4d. It just might make a difference. do tell me if this works !!!! Regards Mike Link to comment Share on other sites More sharing options...
STRAT Posted October 14, 2005 Share Posted October 14, 2005 Try saving the dxf files from autocad as version 12 dxf, version 14dxf and then try importing it into c4d. It just might make a difference. do tell me if this works !!!! Regards Mike i agree. when exporting 2d data into c4d, export it using the r12 format. maxon officially claims that anything later than r12 will be unreliable. Link to comment Share on other sites More sharing options...
