joseph alexander Posted October 19, 2005 Share Posted October 19, 2005 Is there a quick way to get my tree alpha map to stretch to the extents of each plane, besides individually uvw mapping each one? Link to comment Share on other sites More sharing options...
STRAT Posted October 19, 2005 Share Posted October 19, 2005 yup, take you tree maps into photoshop and crop them to the edges of the picture, then just update the material's alpha map with your freshly cropped image map. Link to comment Share on other sites More sharing options...
joseph alexander Posted October 19, 2005 Author Share Posted October 19, 2005 rrr. I didn't explain that well.. I have all these planes, usually I have one tree group and array them in viz, but this time I just have the planes.. is there a way to get the map to align itself to fit each of the planes, without indvidually alpha mapping each plane... this make sense? -joe Link to comment Share on other sites More sharing options...
Tim Saunders Posted October 19, 2005 Share Posted October 19, 2005 aren't you alpha mappinf the material itself? like this: image1=plane with material applied, in shaded mode. image2=plane in wire frame image3=my material with tree map in diffuse and alpha map in opacity. Link to comment Share on other sites More sharing options...
Tim Saunders Posted October 19, 2005 Share Posted October 19, 2005 if you have your material set up like this, all you do is select each plane, and apply the material and the mapping is automatic if you did what strat said. Link to comment Share on other sites More sharing options...
Bugga_Guy Posted October 19, 2005 Share Posted October 19, 2005 If you are using Max, apply a UVW modifier and use the "plane" option. Once applied, click on Fit button, and make sure the proper direction is used (either x, y, z) Link to comment Share on other sites More sharing options...
