rpc problem
Tim Saunders
hey tim,
am not sure if vray free has a vray window. i encounter those circle things also but with the materials i use. what i do is look in the vray window what returns first as overbright then i either change the material or delete it. my problem with rpc especially the people is the reflections in mirrors. they have the wrong reflection. for example, if my rpc is turning its back on the mirror, what it reflects is its front. then when i turn on the cast reflections, it shows the right reflection on the upper half of the body but the wrong reflection on the bottom half. i used vray mat with reflect at white and refract on black with no vraymap. so i hope anyone has the solution to this problem.
yeah i'd second that about reflections being switched off
i use renderdrives and they really do not like the rpc to reflect
also there does seem to be a point with the cars where it takes forever to calculate the meshes (say over 10-15 cars and for animation it takes longer to laod the frame than render it)
It happens to me as well from time to time, when there is a lot of rpc and machine is running out of RAM. The way I manage to keep all the RPCs and render the scene is to render it in passes, let's say 30 RPC at 1 pass ( everythin else is matte mat. ) and composite it together later.
good idea. what's the easiest way you get the matte material off and on everything? do you just have a seperate scene that is an exact copy of the original, or do you apply the material, and after it renders hit undo? or niether? it just seams like a pain to go back an re-apply everything to the whole scene after the matte has been applied.
