muzzy Posted October 21, 2005 Share Posted October 21, 2005 We are planning to upgrade next weekend to max 8. Do you know is there any known issues with Max 8 and 3GB switch ? Anyone upgraded ? Thanks Link to comment Share on other sites More sharing options...
alkis t. Posted October 21, 2005 Share Posted October 21, 2005 we ve upgraded 3 machines so far with 3gb swithch with no problem so far regards Link to comment Share on other sites More sharing options...
muzzy Posted October 21, 2005 Author Share Posted October 21, 2005 thanks, alkis Link to comment Share on other sites More sharing options...
dbarc Posted October 21, 2005 Share Posted October 21, 2005 There are some reports of possible issues with the 3 gig switch and max8 over at the chaosgroup forums but nothing conclusive yet.. Will update when I hear more. Link to comment Share on other sites More sharing options...
muzzy Posted October 21, 2005 Author Share Posted October 21, 2005 There are some reports of possible issues with the 3 gig switch and max8 over at the chaosgroup forums but nothing conclusive yet.. Will update when I hear more. Our IT guy looked at the issue and he said there is no known problem with max 8 and 3GB switch. But we will see in two weeks when we upgrade Thanks Link to comment Share on other sites More sharing options...
abicalho Posted October 21, 2005 Share Posted October 21, 2005 The problems usually happen with video drivers and other device drivers which expect the 2-4GB memory space to be free. Also, the 3GB switch is not supported by 64 bit machines. Make sure you make a safe entry in your Boot.ini before messing with it. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted October 26, 2005 Share Posted October 26, 2005 Well....WHAT is 3GB switch? How can I use them? and have to do? Link to comment Share on other sites More sharing options...
Jeff Mottle Posted October 26, 2005 Share Posted October 26, 2005 Well....WHAT is 3GB switch? How can I use them? and have to do? Everything you wanted to know about the 3GB switch and then some. http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted October 27, 2005 Share Posted October 27, 2005 Everything you wanted to know about the 3GB switch and then some. http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx Thanx on answer, but I still have one quastion [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(2)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(2)\WINNT="????" /3GB is there SPACE before "/3GB", that's because I'm afraid to change the .ini file, and Win wont boot? Link to comment Share on other sites More sharing options...
abicalho Posted October 28, 2005 Share Posted October 28, 2005 You should *ALWAYS* create a second entry without the 3GB switch as a backup: multi(0)disk(0)rdisk(0)partition(2)\WINNT="My OS with 3G" /3GB multi(0)disk(0)rdisk(0)partition(2)\WINNT="My OS with 2G" In this case you can go back if anything fails. Link to comment Share on other sites More sharing options...
muzzy Posted November 1, 2005 Author Share Posted November 1, 2005 We installed max 8 and it works with 3gb switch. Max 8 has bugs with Snap when gizmo is on, network render monitor crashes, and I heard other bugs but those are we found in two days.. It is overall nice but will be better with HOTFIX. Stay with 7.5 until hotfix. Link to comment Share on other sites More sharing options...
