STRAT Posted March 22, 2003 Share Posted March 22, 2003 hi guys please can someone explain to me what the different types of RAM are please? you now can get things like SD RAM, DDR RAM, DDRSD RAM, RD RAM etc... what is what and used where, and how do the speeds compair? it's all hurting my head a bit. Link to comment Share on other sites More sharing options...
bigcahunak Posted March 22, 2003 Share Posted March 22, 2003 SDRAM goes in older systems. went up to 133mhz and died arround the time P4s came out. DDR=DDRSDRAM=DDRxxx the stuff that goes today. Double Data Rate SDR (SDRx2). DDR2100 (266MHZ FSB) 2x133sdr DDR2700 (333MHZ FSB) 2x166sdr DDR3200 (400MHZ FSB) 2x200sdr RDRAM was originally planned by Intel to be the P4s higher end system's memory, whie the older SDRAM would go in the lower end P4 rigs. Well... Intels plans failed to follow as RDRAM's price was way to high to justify the marginal increase in performance. Also, demanded more PSU power and generated more heat... Bottom line - DDR is the way to go. Link to comment Share on other sites More sharing options...
Greg Hess Posted March 22, 2003 Share Posted March 22, 2003 Here's some bandwidth info. The bandwidth of the DDR is also dependent on the bandwidth available on the front side bus. Having 400 Megahertz DDR (PC3200) doesn't do much if your running at a 200 Front Side Bus. Quick Terms.... DDR=Double Data Rate QDR=Quad Data Rate In DDR, the chips have the ability to send data at both the peak and pits on the clock cycle. (Think of a Sin Curve), QDR [P4's FSB] has the ability to send two bits of data on both the peak and the pit. Here's a great article on bandwidth, latency and such. http://arstechnica.com/paedia/b/ban...-latency-1.html ****These are "theoretical" maximums and NOT real world maximums**** SDRAM PC66 (66) 533 mb/sec PC100 (100) 800 mb/sec PC133 (133) 1.06 gb/sec PC150 (150) 1.3 gb/sec Rambus (In Dual Channel Mode) PC600 (600) 2.1 gb/sec PC700 (700) 2.8 gb/sec PC800 (800) 3.2 gb/sec PC1066 (1066) 4.3 gb/sec DDR PC1600 (200) 1.6 gb/sec PC2100 (266) 2.1 gb/sec PC2700 (333) 2.7 gb/sec PC3200 (400) 3.2 gb/sec PC3500 (440) 3.5 gb/sec DCDDR (Dual Channel DDR) PC2100 (266) 4.2 gb/sec PC2700 (333) 5.4 gb/sec PC3200 (400) 6.4 gb/sec 100/133 FSB 100 800 mb/sec 133 1.06 gb/sec Athlon EV6 Bus (DDR) 200 1.6 gb/sec 266 2.1 gb/sec 333 2.7 gb/sec Pentium IV QDR Bus 400 3.2 gb/sec 533 4.3 gb/sec 800 6.4 gb/sec Its interesting to note how the DDR400 (PC3200 DCDDR) fits perfectly with intel's recently announced 800 FSB. Rambus couldn't even begin to touch upon that much bandwidth, so its easy to see why intel completely abandoned that particular memory technology. Link to comment Share on other sites More sharing options...
