AJLynn Posted October 26, 2005 Share Posted October 26, 2005 Sorry to post something so basic, but this is frustrating me and I can't figure it out. I used a closed spline to make a extrude nurbs with caps set to 'regular grid' which was nice because I could make the grid work just right (the shape is irregular). I want to be able to vertex paint so I use make editable - but instead of one mesh I get a mesh for the sides of the object, with 2 child objects for the caps. How do I make these all one mesh so I can vertex paint it? I tried turning off the caps then using close polygon hole, which makes the caps as single polys in the mesh - which I can triangulate but I can't get my nice grid. Link to comment Share on other sites More sharing options...
Frosty Posted October 26, 2005 Share Posted October 26, 2005 After you have made the sweep nurbs editable, select all three parts (tube and both caps). Under the function menu, select "Connect". This will create a duplicate object with all three peices joined. Next select the new object and switch to point mode, select all points (ctrl-A to do it quick). Use the "Optomize" command under the Function menu to weld duplicate points together and create a perfect mesh. Link to comment Share on other sites More sharing options...
AJLynn Posted October 26, 2005 Author Share Posted October 26, 2005 That's exactly what I needed. Thanks. Link to comment Share on other sites More sharing options...
leed Posted November 2, 2005 Share Posted November 2, 2005 another way is to delete all the objects except one of the caps, and then extrude that to the height you want. Lee Link to comment Share on other sites More sharing options...
Frosty Posted November 2, 2005 Share Posted November 2, 2005 That would certainly work on a simple shape, but I think andrew was speaking a more complex sweep. Is there a way to extrude along a plath? Link to comment Share on other sites More sharing options...
leed Posted November 3, 2005 Share Posted November 3, 2005 There is a plugin that allows you to extrude along a spline, but it only works pre V9, Michael Haller, the creator of eas is currently working on an update for v.9. Not certain when it will be available. But I did not read 'sweep' in the original post. Lee Link to comment Share on other sites More sharing options...
AJLynn Posted November 4, 2005 Author Share Posted November 4, 2005 leed said: There is a plugin that allows you to extrude along a spline, but it only works pre V9, Michael Haller, the creator of eas is currently working on an update for v.9. Not certain when it will be available. But I did not read 'sweep' in the original post. Lee 9 has sweep - make sweep NURBS object and drop in the thing being swept, and the path spline, in that order, very easy. But yeah, Connect was it, and Optimize with tolerance at 0, all my points are nice and welded. Here's something I made with it, part of a series of experiments in my thesis research: Link to comment Share on other sites More sharing options...
