Storefront...
jtiscareno
depending on how good your render is, dupliacte the layer in PS then make duplicated layer a hard light layer set transparency to 35% this should have helped with the depth of the image,
If it sgeneric go take a photo map it onto a flat panel recess it into your window area and render with spot lights acting as track lighting in the window display, Render the do as above in PS.
you cant cheat and make it look very good, it needs some depth...
good luck
