7.5 radiosity making things egg-yellow!
Ricardo Eloy
Everything is fine. Tried using simple standard mats, then tried with Advanced Lighting Override, and then Architectural Mats. Same results. The funny thing is that this scene is the one I use to teach radiosity and has been done by me like a thousand times (always on 7.0). Weird, weird...
mate..this thing have nothing to do with upgrading..i guess, i used to have same problems before.when u use radiosity your exposure settings are set to logarethmic by default & that causes the yellow thingy...go to the environment menu & check things out..& change the logarethmic to no expodure...
hope this was helpful
Already tested that. Nothing to do with the problem, I'm afraid. I tried Automatic, Pseudo-color, Linear and actually no exporure control at all and the yellow monster is still there. One thing that seemed to work was restarting my system. But, hey, that shouldn´t happen!
Rick,
I had that happen with VIZ 2005. Does it happen if you set the IES to Diffuse instead of using a file? I had sent a sample scene to Autodesk, explaining the bug, but I guess it's not solved yet. I can't remember exactly how I worked around it. It seemed to have something to do with objects set to not cast shadows in Advanced Lighting.
Actually, what I meant was that I thought removing the shadows in Advanced Lighting caused the problem. I was trying to keep a bunch of diffuser fins from casting shadows in a luminaire.
I suspect this is an unpredictable bug that may not have a solution and will either show up or it won't.
Very unpredictable, I may add. I was teaching radiosity to 7 students when I first crossed this bug. Nothing I did seemed to work, and just like it started, it would go away (not at the same time in all machines, of course). About the shadows, I guess that's not the problem, coz it happened either way. My guess was that the new Adaptive Subdivision feature introduced with 7.5 had something to do with it, since I had never seen anything like that before, but if you had the same problem with Viz 2005, my theory goes down the drain...
We could really use a help from Autodesk/Discreet/whatever-they-call-themselves' support now, huh? ;)
  • 1 year later...
Well, Swapnil, I really appreciate your support, but the (old) problem is solved, already. It seems there was a bug regarding the lights in Max 7. The egg-yellow thing had something to do with the color Max assigns the light objects. Once I changed the color (object color), it worked.
Thanks, anyway.
Hi, Angela. It's been a really long time since I stopped using radiosity, but this is what I did to solve the problem back then. Cheers!
... It's been a really long time since I stopped using radiosity...
Thanks for your reply. I was reluctant to modify any of the IES sun parameters, but I'll give it a try.
It's seems that not many people are using radiosity today. At least there are old posts!!! Not much new stuff, and less with accurate lighting.
Thanks again, Angela
Angela, you don't need to change the Sun's color. It's just the object color (right-click on the sun -> Object properties -> Color). The radiosity engine seemed to be taking the light color from the object's color instead of its regular parameters. Anyway, it's been a looooong time since I last messed with radiosity, which makes it a bit hard to remember every detail... ;)
