The Trickster Posted November 1, 2005 Share Posted November 1, 2005 Hi All, A quick V-ray question if you please. When doing external renderings do peeps tend to use V-ray lights or max lights or a mixture of both?? Or does it not matter? Cheers! Link to comment Share on other sites More sharing options...
Arnold Sher Posted November 1, 2005 Share Posted November 1, 2005 standard directional light that comes with max with vray shadow on.. Do not forget to switch environment on in vray rendering menu and take the tick off default light.. hope that helps Link to comment Share on other sites More sharing options...
The Trickster Posted November 1, 2005 Author Share Posted November 1, 2005 Thanks Arnold, This is my first exterior with V-ray. I have built this model in cad. Do you have any more hints and tips for external settings? I will posr my progress as i go along. Thankyou. http://img65.imageshack.us/img65/5358/test1zx.jpg Link to comment Share on other sites More sharing options...
gfa2 Posted November 1, 2005 Share Posted November 1, 2005 Looks like the colors are from CAD. Once you put some textures on there, it should tone it down a lot. I'm with Arnold, I use a max directional light with vray shadows. Chris Nichols used a vray light on his DVD for his outside scene, but I haven't tried that yet. Link to comment Share on other sites More sharing options...
kippu Posted November 1, 2005 Share Posted November 1, 2005 very neat ..... its coming along very good ...put the textures mate Link to comment Share on other sites More sharing options...
Jeff Mottle Posted November 2, 2005 Share Posted November 2, 2005 Might want to take a peek at your exposure control as well. Seems a bit blown out. Could also be the value of your direct light though. Link to comment Share on other sites More sharing options...
anvaraziz Posted November 2, 2005 Share Posted November 2, 2005 turn off default lights from v-ray global settings, Link to comment Share on other sites More sharing options...
The Trickster Posted November 2, 2005 Author Share Posted November 2, 2005 Thanks guys, Exposure control was not on i think the burn was coming from my direct light. I have applied a few materials and its coming along. Hope you like. Can anyone tell me what the Frame buffer and irradiance map are for? My enviroment light is 1.0 and my direct is 0.5 using vray shadows and adaptive subdivision. Thankyou for your imput! It is appreciated. http://img477.imageshack.us/img477/2408/test016dr.jpg Link to comment Share on other sites More sharing options...
piotrgreg Posted November 3, 2005 Share Posted November 3, 2005 hi, if u r new to vray, this could help a bit: http://www.vrayrender.com/login/ good luck Link to comment Share on other sites More sharing options...
piotrgreg Posted November 3, 2005 Share Posted November 3, 2005 oh, I forgot, dont keep to same settings all the time - just remember them if u wish change shadow casting, reflections, mapping with every trial add some omni light somewhere ( work with attenuation though) this will arm u with a new weapon:) I believe in Your experiments good luck Link to comment Share on other sites More sharing options...
