ovzoc Posted November 2, 2005 Share Posted November 2, 2005 Hi in Autocad 2002-4-5 when you pressed the up arrow it showed you the last value (or command) you had entered. For example when I wanted to repeat a value( 5 meters for example) in line command I simply had to press the up arrow and it was ok.In Autocad 2006 when I am in line command and press the up arrow instead of giving the last value it shows the last endpoints coordinates. How can I change this and make it act like the older versions? Excuse my English I'm not the best English speaker of the world Link to comment Share on other sites More sharing options...
Audrie Posted November 3, 2005 Share Posted November 3, 2005 Your english is fine except for crazy american spelling! My Autocad 6 has the upkey automatically bringing up the last commands, so I am guessing your setting in the Customise user interface has a keyboard shortcut acting differently. Go TOOLS/CUSTOMISE/INTERFACE Then select Keyboard Shortcuts from the list. Link to comment Share on other sites More sharing options...
bigroo Posted November 3, 2005 Share Posted November 3, 2005 Hi ovzoc, As far as I can see using the UP ARROW & DOWN ARROW only allows toggling through the last commands. Surely creating a block or pasting the item in question will reproduce the identical item value. Link to comment Share on other sites More sharing options...
Spongebob Posted November 4, 2005 Share Posted November 4, 2005 I too have noticed this change made to my ADT 2006. It is unfortunate and I have been meaning to fire a message off in the ADT newsgroups voicing my saddness in seeing this functionality gone. I have since found that there is a 'recent input' available in the right-click menu, but it only seems to list recent commands and not recent distances or direct distance/polar coordinants. Jeffrey Link to comment Share on other sites More sharing options...
