kippu Posted November 3, 2005 Share Posted November 3, 2005 i recently got some drawings done in ADt and after i opened them in autocad it was in blocks... now these blocks dont export well into max ... can anyone help ? Link to comment Share on other sites More sharing options...
bigroo Posted November 3, 2005 Share Posted November 3, 2005 Explode your blocks to create 2D lines maybe? Link to comment Share on other sites More sharing options...
ovzoc Posted November 3, 2005 Share Posted November 3, 2005 What exactly do you want to do? Tell us details about the file formats you are using for import-export to max (3ds? obj? dwg?) and what is the work you have to do... (3d ? 2d?) so that we can provide you with info Link to comment Share on other sites More sharing options...
Spongebob Posted November 4, 2005 Share Posted November 4, 2005 If you have a drawing created in ADT which was not converted prior to being sent to you I believe the AEC objects within the drawings will show up as 'proxy objects' and are entirely un-editable to you. If this is the case you may need to ask the source of the drawing to 'Export to AutoCAD' from the file menu and then re-send it to you. On the other hand if the person who sent you the drawings had the foresight to convert the drawings beforehand they will most likely show up as blocks and can be edited using the 'refedit' command. Jeffrey Link to comment Share on other sites More sharing options...
