Problems with tile map on VRay
carlangas
The tiles look fine. Seems that there may be an issue with the "type" of reflections you used on them. Maybe you have some some drop-dead fallof in the reflection channel or there may be too much "light" on the geometry area not showing reflections. Incident light on a reflective surface will eventually kill the reflections when it becomes greater than the "light" on the object being reflected.
Oh, and it could be something else. Do post what it was when you find it.
Ismael
One more idea:
If it is a Vray material, check the "Options" tab. Default "Cutoff" should be 0.01, and if too large it may be a cause. If a VrayMap in in the reflection slot of a Standard Mat, there the standard Cutoff Threshold should be 0.1
Just maybe that is it.
Good luck,
Ismael
P.S. You would not have a Direct Light set to not cast shadows in the scene?
Just one more thought...
