treeshop plugin question
fernando-1
When you start the plugin it asks you at the top to load a material library. Now if you go to the material editor after loading the library and click "Get Material" /From Mtl Library, you should see the trees in that library. Drag one of them to the Material Editor and you'll see that it is a Standard Material with a Diffuse and an Opacity Map.
What you do then is to create a material like that and save it to your own Library. Then; next time you use the plugin, you just load the Library that contains your new creation.
That is all. I like that Plugin myself and have been always very thankful to Marc Lorenz for giving it so generously.
Hope it works for you,
Ismael
I use Viz 4 and TreeShop v2.0 which allows for a "Look at Controller" to be assigned to the trees or plants. That is what you need and that plane you mentioned will be perpendicular to the camera you selected. Of course if you have Max 6 and up you can use v2.5 which I believe is the latest build but does not work with Viz 4.
That's it I think,
Ismael
Post an image with the problem. Use imageShack if you don't have web space.
Ismael
Edit:
You may just go to the Object properties and uncheck Receive Shadows. Those trees are quite presentable and nice, but they are just 2D looking like 3D. Have fun and if you find another answer to the issue, please do post it.
