2 questions about "Undo" command
1eo
Greetings,
1. is it possible to exclude "INTELLIZOOM" from the undo comand???
2. I got a new pc, that should be pretty fast (AMD dualcore 64 4200+, 2GB ram)... However, for some reason when I use the undo command... the pc takes a while to execute it!! (All other commands are fine). I didn't have that problem with my other machines, so I know there must be some diffrent settings some where..
Thanks a lot!
Regards,
Leonardo
AutoCAD 2006 now has an option (ON by default) to group pan and zoom operations. This way if you undo it then it goes back all the changes in view you made. However it still consider the intellizoom as a command so it undoes it aswell.
There doesn't seem to be a way to bypass this right now.
Did you test for any incompatibility between AutoCAD and AMD's dual cores? Should give it a search in Google or the Autodesk forums.
