best way to do corner trim??
RAYMOND
doing corner trim now with mass element which works fine
but if i have to change all the trim say to a wider size then
its a just a timely hassle...
is there away to automatically have this done...
so we can change all the trim at once like a style change
give me convience or give me death.:confused: :confused: :confused:
interesting suggestion.
but tabsurf, i don't think would be an object that could be edited like a ADT style... using mass element would be better anyway..
you could do this also as a block but then it would not be anchored into the wall corners.
sorry, i know my english is quite beyond...
well this would work but.
a mass element is the same thing in that hieght can be changed in properties. and you can just type in the hieght for either single or multple
with a block using zscale you have to have a scaling factor to deal with..
actually i don't see why ADT doesn't address this since it is so common.
