Ernest Burden III Posted November 7, 2005 Share Posted November 7, 2005 I used to use a feature of the basic recorder within Windows (probably in the NT4 days, maybe W2K) that would simply record whatever was playing into a certain format. It doesn't seem to be anywhere that I can find in XPpro. One way I had used this was--I had gotten some sound recordings off the web of people speaking in Old and Middle English, and needed to make a CD for my wife to play to her students (she teaches 6th Grade English), but the files were in a weird format. So play the file while running 'record what you hear' set to standard CD settings worked. So where'd it go? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted November 7, 2005 Share Posted November 7, 2005 are you referring to 'sound recorder'? ...it was definitely nt 4 days. not sure if it records all sounds though. i think it makes basic wav files as an output. start > programs > accessories > entertainment > sound recorder or c:\windows\system32\sndrec32.exe ...if that is the right one. Link to comment Share on other sites More sharing options...
wilky9 Posted November 7, 2005 Share Posted November 7, 2005 Well sir, if I follow you, what you want is the "Sound Recorder" found in Accessories/Entertainment/ To record at higher quality, click File/Properties/ then in the Format Conversion box, select Recording Formats and Convert Now. Then change the recording quality. If it is not recording the signal you want, select Edit/Audio Properties, and click the Volume button. Select the signal you want to record. I selected Wave/MP3 to record a streaming audio recording off of the internet. Hope this helps. Let me know if I can help any more. chris Link to comment Share on other sites More sharing options...
BobM Posted November 7, 2005 Share Posted November 7, 2005 It has always been there my students record tracks an take into 3ds max all the time. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted November 8, 2005 Author Share Posted November 8, 2005 It has always been there Thanks, but I know where the sound recorder is. The problem is I cannot see any way to make it 'record what you hear', which is something I feel I have done with it, or some earlier version of it, before. Now I can't. There used to be an option for input of 'what you hear' in addition to microphone, line-in, etc. I don't see it anymore in XP. Where'd it go? Link to comment Share on other sites More sharing options...
anvaraziz Posted November 8, 2005 Share Posted November 8, 2005 hey dude that , record wht u hear option comes only if u have a good audio card like , creative soundblaster platinum or heigher... that option ll not show if u use onboard sound or a normal entry level soundblaster... if ur using any such sound card, try to reinstall those softs comes with driver CD.. Link to comment Share on other sites More sharing options...
paveu Posted November 8, 2005 Share Posted November 8, 2005 I have a standard onboard sound in my machine. For recording anything I hear using mp3directCut (http://www.mpesch3.de/). You only need to install Lame encoder DLL or ACM and it records anything writing to mp3 format. Maybe this helps... Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted November 8, 2005 Share Posted November 8, 2005 Thanks, but I know where the sound recorder is. The problem is I cannot see any way to make it 'record what you hear', which is something I feel I have done with it, or some earlier version of it, before. Now I can't. There used to be an option for input of 'what you hear' in addition to microphone, line-in, etc. I don't see it anymore in XP. Where'd it go? hmmm... i don't remember a button like that. what format is the current fomrat of the audio? ....mp3's were just starting to emerge at the end of nt4's life cycle. so, they may not be supported by sound recorder. a lot of modern cd burning apps, like nero for example, will let drag and drop mp3 audio and tell it to burn it to audio cd format. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted November 8, 2005 Author Share Posted November 8, 2005 what format is the current fomrat of the audio? I don't have a current file I'm trying to use, just want to be able to use my uber-easy method to convert anything to CD standard--16bit@44.1 (from memory). record wht u hear option comes only if u have a good audio card like , creative soundblaster platinum or heigher That may explain it, then. I used to use seperate SB sound cards, mid-level, but all my machines now have nVidia motherboard chips for audio. Since I make pictures, I was willing to go cheap on the audio. Of course I'm listening to it all day, and I'm an alledged audiophile, so I defiling myself by stooping so low. Blasted, cursed! Link to comment Share on other sites More sharing options...
