The Trickster Posted November 10, 2005 Share Posted November 10, 2005 Hi, Can anyone help me out with creating a good and realistic copper cladding finish ? I have created a couple of materials using reflection, bump, and tile with maps and reflections inside the raytracer and its come out ok but im looking for something better with more realism. http://img499.imageshack.us/img499/3896/test02620x4371oz.jpg Thanks to anyone who can help with this! Link to comment Share on other sites More sharing options...
dp_araujo Posted November 10, 2005 Share Posted November 10, 2005 In annex have a material for Max, I hope can help you. Link to comment Share on other sites More sharing options...
JamesTaylor Posted November 10, 2005 Share Posted November 10, 2005 what software are you using Phil? is it viz / max with vray? Link to comment Share on other sites More sharing options...
The Trickster Posted November 13, 2005 Author Share Posted November 13, 2005 Hey James, Its Max but im using default scanline. dp araujo - thanks mate, ill give them a try. Link to comment Share on other sites More sharing options...
Tim Saunders Posted November 15, 2005 Share Posted November 15, 2005 i did one once that i was pretty happy with. i used a standard material. i loaded a mix in the diffuse slot. in the top mix slot i loaded the attached map. then i mixed in a little bit of a goldish color. then i cranked the specular value up to like 75-85 and left the glossiness at 10. thats it. renders fast and looks good too. gove the object some uvw mapping so you get the variation in the map the size you want of coarse. Link to comment Share on other sites More sharing options...
The Trickster Posted November 15, 2005 Author Share Posted November 15, 2005 Cheers mate but i have finished the job now. The result can be found in the 'Lens flare' thread in this forum. p.s i sent the one without LF! Link to comment Share on other sites More sharing options...
Tim Saunders Posted November 15, 2005 Share Posted November 15, 2005 oh your talking about nice copper. not the old rustic stuff. looks good. Link to comment Share on other sites More sharing options...
