balaji3d Posted November 11, 2005 Share Posted November 11, 2005 Hi Everybody, I am a 3D Animator,my client needs photorelastic architectural renderings can any body help me out how to produce this renderings Suggest me any tutorials or techniques Link to comment Share on other sites More sharing options...
STRAT Posted November 11, 2005 Share Posted November 11, 2005 what software do you use? Link to comment Share on other sites More sharing options...
balaji3d Posted November 11, 2005 Author Share Posted November 11, 2005 3d studio max7 Link to comment Share on other sites More sharing options...
ecastillor Posted November 11, 2005 Share Posted November 11, 2005 definately use some sort of GI or radiosity.....and use a renderer if you can (vray, maxwel.....) Link to comment Share on other sites More sharing options...
Guest sachinwalvekar Posted November 11, 2005 Share Posted November 11, 2005 hi, look if u going to be making arhictectural renderings for the first time....I suggest.....u start by : 1. looking into architectural autocad drawings given by ur client. 2. usually I import the wall outlines & window / door opening outlines in 3dsmax. 3. Extrude the walls in 3dsmax & similarly make window panes & glass from imported outlines. 4. assemble all of it in 3dsmax. 5. Deliver preliminary renderings showing the completed geometry in 3dsmax. 6. I use directed light for this setup & another fill light, keeping the ambient 0,0,0. This is to have the complete range of tones. 7. For the final use daylight system......Gives good results but is time consuming. I have just myself started on this. 8. There r plenty of 3d foliage available on net, or u could use opacity maps, take care u will need to use raytracing for shadows from opacity maps. There r some good tutorials by smoke on lighting in the tuturial section. best luck. sachin. Link to comment Share on other sites More sharing options...
quizzy Posted November 11, 2005 Share Posted November 11, 2005 .....by looking at/observing the real world Link to comment Share on other sites More sharing options...
anvaraziz Posted November 12, 2005 Share Posted November 12, 2005 study the dwg first.... finish ur model... photorealism comes out by the way u do ur textures and lighting.... take a look on the real world,shadows,highlights, reflections, refractions, then with a good GI render u can make it... but sure using GI will not give u out put with in 1 or 2 min,... press render , go for a movie, :) Link to comment Share on other sites More sharing options...
