Quique Posted November 11, 2005 Share Posted November 11, 2005 I'm having a problem w/Max 8 crashing whenever I try to render Hair & Fur applied to an object using Mental Ray as the renderer. I've tried changing the Render>Effects>Hair & Fur from Buffer to Geometry or MR Primitive and get the same result. I created the most simplistic scene of a MR spot light, and a plane with the Hair & Fur modifier applied. Using scanline renderer works fine, btw. Can anyone duplicate this problem? Maybe someone can make a simple scene as described above, can you render it, prove it works fine, and send it to me in case I'm missing something? Thanks, Quique 4 days and no respones. Can someone please take 2 minutes out of his/her busy schedule to try and replicate the problem stated above? Or even just confirm from experience that the setup described above works fine? Thanks, Quique Link to comment Share on other sites More sharing options...
