spyder2411 Posted November 12, 2005 Share Posted November 12, 2005 Can someone explain what is happening with the lighting? I'm getting these white balls all over the place. Link to comment Share on other sites More sharing options...
njoco2 Posted November 12, 2005 Share Posted November 12, 2005 Make sure that all materials on your scene are Vray materials. I used to get those bright spots every time I used Vray and default max materials. I`m using Vray 1.09. Cheers Link to comment Share on other sites More sharing options...
JamesTaylor Posted November 12, 2005 Share Posted November 12, 2005 vray doesn't seem to like some of the standard max maps, such raytrace. you can still use standard materials but you'll have to hunt down the offending map by turning materials off until you can render without the issue Link to comment Share on other sites More sharing options...
d.sign Posted November 12, 2005 Share Posted November 12, 2005 It looks like you turned on the show samples option... Or you use some of the materials that can cause problems... Link to comment Share on other sites More sharing options...
anvaraziz Posted November 13, 2005 Share Posted November 13, 2005 first make sure ur not using raytrace........ if sure then its with photometric lights and v-ray... try to turn off those photmetric lights and put v-ray lights ,, and chek,,,, update ur v-ray... i too have same prob with 1.09 ... Link to comment Share on other sites More sharing options...
spyder2411 Posted November 13, 2005 Author Share Posted November 13, 2005 After a few tests, it appears that anything with a reflection tends to give me the "blobs" and I'll just end up putting them in post. Pretty sad considering stainless steel materials generally have somewhat of a distorted reflection. Link to comment Share on other sites More sharing options...
David Knourek Posted November 13, 2005 Share Posted November 13, 2005 As posted above, V-Ray does work with standard amx materials but does not work with max's raytrace material. What version of V-Ray are you running? -dave Link to comment Share on other sites More sharing options...
spyder2411 Posted November 13, 2005 Author Share Posted November 13, 2005 Currently using the free demo until I can get a couple projects to cover the costs of the the full version. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted November 13, 2005 Share Posted November 13, 2005 Therefore don't use the 3ds raytrace material but the vraymap material under the reflection slot. Link to comment Share on other sites More sharing options...
