Corporate Building
EricMLevy
Thanks for the responses. I will sharpen those bushes up, you're right, they're too blurry. I think the image blurs by default in max.
The tree and bollard-- i was wondering what those were called-- do have shadows, but I covered them up by mistake, with my grass layer.
I must have to calibrate my monitor since you both think it is too dark.
Thanks for the help.
I'll post a final render when it's all said and done.
Someone asked about the glass:
  • VrayFree.
  • Blinn shader, no spec level, no gloss.
  • 25% opacity
  • Very dark blue, almost black.
  • Vraymap in the reflection slot, reflecting almost 100%
  • An image that I modified based off of MEADOW.jpg that comes with Max, in the Environment Map (press 8 when you're in Max).
The geometry was very simple. A plane, the edges had a less reflective, more opaque version of the same shader to fake that line between each pane of glass.
