Jerry Wilkes Posted November 18, 2005 Share Posted November 18, 2005 Hi, I have a minor problem with Viz 4; 1. I should be able to copy an object by simply selecting it, and then dragging it to one side whilst holding down the ‘Alt’ button. I can’t do that anymore. 2. I should also be able to drag an object along one of its axes( locked to that axis), just by selecting the object and moving over the relevant axis. That facility has also just gone. 3. Would "loading the default VIZ interface" solve this( & if so how do I do that?), or do these things just toggle on or off !! Any ideas? Thanks, Jerry ( Bristol,UK) Link to comment Share on other sites More sharing options...
JamesTaylor Posted November 18, 2005 Share Posted November 18, 2005 in respect to your first problem, it is shift that you need to hold down, not alt. it should then work as planned. 2nd point.......not too sure about this.... but if you've pressed alt, it'll highlight the main menu bar, you won't be able to move anything until you come out of the alt command by pressing esc. rebooting viz should restore your defaults, but since its possible to update the defaults you may have saved the change and it'll still be there. Link to comment Share on other sites More sharing options...
Jason Matthews Posted November 19, 2005 Share Posted November 19, 2005 When you grab the objects select the move tool. Then move the cursor over the x,y,z, axis. The axis you move on is highlighted in yellow I believe. Link to comment Share on other sites More sharing options...
piotrgreg Posted November 19, 2005 Share Posted November 19, 2005 to copy an object: select an object right-click select "copy" from the right-cilck menu - now u created a new object- choose options: reference, instant or copy move it that 's all Link to comment Share on other sites More sharing options...
Brolloks Posted November 24, 2005 Share Posted November 24, 2005 To copy object select object to copy press ctrl+v follow the prompts Link to comment Share on other sites More sharing options...
