Nvidia graphics card
Hi all
Is the Nvidia Quadro FX 540 good enough for 3d work - 3d max, lightwave etc, or should I be considering the FX 1300??
My system (will be) AMD 3800 dual core, Asus A8N motherboard...
I've got a limited budget which extends to about the 540, but if this - being entry level; is not professional standard, I guess best to save some more???
Thanks - Blair
Depends on how complex your work is, I think - for me, a Quadro4 900 is perfectly adequate (most of the time - a while ago I was working with a 3D model of downtown boston and it was painful) and the 540 is faster. With that in mind, compare the numbers in this thread:
http://www.cgarchitect.com/vb/showthread.php?t=12329&highlight=specviewperf
to the numbers at:
http://www.nvidia.com/object/IO_11761.html
Actually, going by nVidia's benchmarks, the 540 is a bit faster than the 1300 for 3DSMax use, but I'm suspicious of that.
to the numbers at:
are u sure ???? as i know , fx540 for 2D application , fx1400 is a good choice for PCie , it depend ur main support . my curent card is fx3400
  jonel said:
fx540 equals nv43 aka GF 6600/GT
so, it can't be that bad.
actualy, I would consider it as a great entry solution :)
fx1400 howerer, equals (if I'm not wrong) FX 5700 Ultra, that can't be better than GF 6600, for sure.
You really can't go by that - different revisions of the various NV cores have dramatically different performances. (The 6600 and 6600GT are both NV43, the Quadro4 900 and 700 are both NV25,, QuadroFX 3000 and 700 are both NV35, etc.) And for the record, QuadroFX 1400, 3450/4000 SDI and Geforce 6800 are all NV41, while the 5700U is NV36, which corresponds to a QuadroFX 1100.
The best info is in the benchmarks. Unfortunately.
(I don't have all this memorized - if you've downloaded nVidia drivers there's a list in c:\nvidia\nvdm.inf)
