Tim Saunders Posted November 21, 2005 Share Posted November 21, 2005 here's a wierd one to think about. this morning i was trying to rander an exterior scene at 3000x2000 and everytime i would hit render viz would crash. but wen i rendered at lowere rez settings (below 1024) it rendered fine. then i disabled the vray frame buffer, and enabled the defalt viz frame window and it rendered full rez just fine. Link to comment Share on other sites More sharing options...
kippu Posted November 21, 2005 Share Posted November 21, 2005 well i never render using vrayframe buffer unless you want the separate elements Link to comment Share on other sites More sharing options...
Christopher Nichols Posted November 21, 2005 Share Posted November 21, 2005 here's a wierd one to think about. this morning i was trying to rander an exterior scene at 3000x2000 and everytime i would hit render viz would crash. but wen i rendered at lowere rez settings (below 1024) it rendered fine. then i disabled the vray frame buffer, and enabled the defalt viz frame window and it rendered full rez just fine. I would let Chaos know about this. Generally speaking you almost always want to use the Vray Frame buffer. Link to comment Share on other sites More sharing options...
dbarc Posted November 21, 2005 Share Posted November 21, 2005 I'm pretty sure Chaos don't recommend using the vray frame buffer for serious work over at the vray forums. I personally don't find it stable enough and reverted a while back. No doubt it will be sorted out in the next beta.. Link to comment Share on other sites More sharing options...
JamesTaylor Posted November 21, 2005 Share Posted November 21, 2005 vray buffer is good for testing - you can use the render mouse location so you don't have to wait for the whole thing, just move your mouse over the areas you need. final renders i do in max buffer, i've not noticed any difference. Link to comment Share on other sites More sharing options...
Ismael Posted November 21, 2005 Share Posted November 21, 2005 May check this: http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=9982&highlight=bitmap+pager Ismael Link to comment Share on other sites More sharing options...
Tim Saunders Posted November 21, 2005 Author Share Posted November 21, 2005 interesting thread ismael, but i don't see any problems mentioned directly related to the vfb. i think i will pass this on the chaos. i love the vrb and hope to use it as often as possible. thanks for your thoughts everyone. Link to comment Share on other sites More sharing options...
dbarc Posted November 21, 2005 Share Posted November 21, 2005 vray buffer is good for testing - you can use the render mouse location so you don't have to wait for the whole thing, just move your mouse over the areas you need. final renders i do in max buffer, i've not noticed any difference. I agree - the functionality beats the max buffer hands down. I have however read threads over at the chaos forums from others outlining issues with it in its present incarnation plus I've had a few myself.. I could be wrong but I think Mr Vray himself Vlado suggested it was probably better to use the standard frame buffer for critical jobs at present.. Link to comment Share on other sites More sharing options...
