HomeBrewTJ Posted November 21, 2005 Share Posted November 21, 2005 Hello all. I've been viewing these forums for quite some time now and thought I'd share a project I'm working on. This is the second exterior I've ever done, and would love some feedback. I'm still working on the glass, and some details in the roof/trim and other little things. I basically just modeled an existing building on campus and put it back into the photo. I used max7 with skylight and a directional and just rendered scanline. Thanks Link to comment Share on other sites More sharing options...
Hector Posted November 21, 2005 Share Posted November 21, 2005 Hello: Nice rendering. My observations woul be: 1.- Shadows on the brick walls of the neigbour building are darker than in your model, I think they should look about the same as they are suppose to be under the same light. 2.- I think windows on the right side side of your building should allow to seesomething of the inside, even if it looks dark. Is the combination of reflections and transparency what makes glass realistic. 3.- the ttop four windows look a bit stange cause two look dark and two look light. Looks grate. Link to comment Share on other sites More sharing options...
kippu Posted November 21, 2005 Share Posted November 21, 2005 nice start and i cant add much to the above noted points Link to comment Share on other sites More sharing options...
JamesTaylor Posted November 21, 2005 Share Posted November 21, 2005 looks great, only thing i'd add is a bit of camera correction needed on the verticles. Link to comment Share on other sites More sharing options...
HomeBrewTJ Posted November 22, 2005 Author Share Posted November 22, 2005 Thank you for the feedback. I definitely need to make the contrast between light and shadows more prominent. And I will add something on the inside of the windows to give them some depth as well. About the windows on top- the two middle ones are actually vented. I know it's hard to tell right now, maybe I should fix that as well. Link to comment Share on other sites More sharing options...
