carlangas Posted November 28, 2005 Share Posted November 28, 2005 Hi all, I need help on deciding which system to get, I can only spend about 2500 bucks. I've been looking at different companies and i think alien has the best bang for the buck. I use max/vray for stills although I will be doing animations in the future. I ended up with these two systems and wanted to get your opinion on these or other systems you know of. MJ-12® 5500i Processor: Intel® Pentium® Processor 840 w/ Dual Core Technology 3.2GHz 800MHz FSB Operating System: Microsoft® Windows® XP Professional with Service Pack 2 Power Supply: Alienware® 650 Watt ATX 2.0 Power Supply with Active PFC Motherboard: Alienware® PCI Express Motherboard with Intel® 955X Chipset Memory: 2GB Dual Channel DDR2 SDRAM at 667MHz - 2 x 1024MB Graphics Accelerator: NVIDIA® Quadro™ FX 540 PCI-E 128MB DDR w/ Breakout Box System Drive: High Performance - 80GB Serial ATA 7,200 RPM w/8MB Cache A/V Work Drives: High Performance - 80GB Serial ATA 7,200 RPM w/8MB Cache Primary Optical Drive: 16x Dual Layer DVD±R/W Drive Secondary Optical Drive: 52x32x52x CD-RW Drive price is $2422.00 and the other system is: MJ-12® 7550i Processor/s: Dual Processor - Dual Intel® Xeon™ Processors 3.0GHz w/ EM64T 800 MHz FSB w/1MB Cache Operating System: Microsoft® Windows® XP Professional with Service Pack 2 Power Supply: Enermax EG465P-VE 24P 460 Watt Power Supply Motherboard: Alienware® X2 Dual Xeon™ Motherboard Memory: 2GB Dual Channel DDR2 Registered ECC SDRAM at 400MHz - 2 x 1024MB Graphics Accelerator: NVIDIA® Quadro™ FX 540 PCI-E 128MB DDR w/ Breakout Box System Drive: High Performance - 80GB Serial ATA 7,200 RPM w/8MB Cache A/V Work Drives: High Performance - 80GB Serial ATA 7,200 RPM w/8MB Cache Primary Optical Drive: 16x Dual Layer DVD±R/W Drive Secondary Optical Drive: 52x32x52x CD-RW Drive price is $2,492.00 thanks for your help Link to comment Share on other sites More sharing options...
carlangas Posted November 28, 2005 Author Share Posted November 28, 2005 One more question, In order to get two buckets rendering at the same time in vray, do you need a dual precessor pc or will the dual cores do it too. Link to comment Share on other sites More sharing options...
J.C Posted November 29, 2005 Share Posted November 29, 2005 Que onda Carlos, Un consejo si me permites I just bought a new workstation with about the same budget as yours $2589 USD to be exact. A dual core opteron 265, 2 gb ram, 160 gb HD, geforce 6600 gt (wich can run as a Quadro fx 540 using rivatuner) but cheaper. supermicro motherboard dvdr dual layer and the usual stuff. The thing is very fast I would say its somewhat faster than the xeon setup you are after. You might want to consider taking a look at http://www.monarchcomputer.com thats where I got it from. I must say I'm pleased with the workstation and I think is a good deal for this budget. Ofcourse I ended up paying well over $3,000 for the shipping, customs etc. Yo creo que estas pagando mucho por la marca pero claro es tu desicion. JC Link to comment Share on other sites More sharing options...
carlangas Posted November 29, 2005 Author Share Posted November 29, 2005 Hi JC, thanks for the input. Ill check out that website. im not very good with precessor types/configurations thats why i was cuoting the dual xeons. Link to comment Share on other sites More sharing options...
gfa2 Posted November 29, 2005 Share Posted November 29, 2005 You get 2 buckets with vray on a PC that has hyperthreading, you don't even need 2 real processors. I have an Alienware m7700 with a 3.8Ghz P4, 2GB ram, 256MB video and (2) 80GB 7200rpm drives in raid 0. This is a great machine but it is very heavy, runs hot and the battery isn't worth a crap (maybe 40 minutes on a full charge), but when you have it plugged in...it is awesome. Link to comment Share on other sites More sharing options...
carlangas Posted November 30, 2005 Author Share Posted November 30, 2005 ok, here is a monarch's system. still open to suggestions. Monarch Empro Custom Workstation Power Supply: 100362 - PS 550W - CoolerMaster Real Power ATX 2.0 Case Fan: 100933 - 80mm - Thermaltake 80mm Case Fan Motherboard: 110681 - Supermicro/Monarch A0110681 (H8DA8) GB-L Processor: 120775 - AMD Opteron 265 Dual-Core 1.8GHz 1MB Heat Sink Fan: 130956 - Thermaltake A1770 AMD Opteron/64 Heatsink Memory: 140258 - DDR (400) 3200 REG ECC - 2 GB (2 pcs 1GB) Hard Drive: 150935 - SATA - Western Digital (WD800JD) 80 GB/72 2nd Hard Drive: 150935 - SATA - Western Digital (WD800JD) 80 GB/72 RAID Setup: None CD-ROM/DVD-ROM/CD-RW: 160949 - DVD±RW - Samsung SH-W162C/BEBN 16x Dual L CD-RW/DVD-RW: 160021 - CD-RW - Lite-On SOHR-5239S 52X32X52 CD-RW Video Card: 190038 - eVGA Geforce 6200 256MB DDR/AGP/TV-Out/DV price is $2,342.39 Link to comment Share on other sites More sharing options...
