ShaunDon Posted November 29, 2005 Share Posted November 29, 2005 Howdy all. I've got a huge site for a hospital expansion that I need to fill with parked cars. I plan to use Dosch 3D cars for the job, but the difficulty comes in placing them all... the site is contoured and in some areas slopes rather dramatically. Does anyone know a way to align a model to the surface of the pavement and rotate it so all four tires are grounded? I assume this is a long shot, but considering the time it would save I just had to ask. Thanks! Shaun Link to comment Share on other sites More sharing options...
Brian Cassil Posted November 29, 2005 Share Posted November 29, 2005 Not a long shot at all. The glue script makes this a complete snap! Check it out at itoosoft here: http://www.itoosoft.com/english/menu.php?id=glue works for splines too. Link to comment Share on other sites More sharing options...
ShaunDon Posted November 29, 2005 Author Share Posted November 29, 2005 What what WHAT? I thought Glue only worked for splines! I'll give that a shot! Link to comment Share on other sites More sharing options...
ShaunDon Posted November 30, 2005 Author Share Posted November 30, 2005 So I gave it a try, but it seems to be aligning my pivot point or center of the object to the face. I also need something that will rotate it perpendicular to the face normal at the same time. I really should try learning maxscripting sometime... Thanks again. Shaun Link to comment Share on other sites More sharing options...
Brian Cassil Posted November 30, 2005 Share Posted November 30, 2005 Maybe I don't quite understand what your trying to do, but from the sounds of it, I would think that checking the "follow normal surface" checkbox would do the trick. Link to comment Share on other sites More sharing options...
ShaunDon Posted November 30, 2005 Author Share Posted November 30, 2005 Sorry Brian, you're right of course. I think I'd been staring at the computer screen for too long last night. Thanks for the help, it works great! Shaun Link to comment Share on other sites More sharing options...
Chris Johnson Posted November 30, 2005 Share Posted November 30, 2005 If you ever want something that is interactive, I suggest Bobo's align tool. It interactively aligns a selected object over a surface. Link to comment Share on other sites More sharing options...
