tcupp Posted November 30, 2005 Share Posted November 30, 2005 I'll see if this can make sense. I have created a curved surface that is animated, like a wave. I have video that I want to project onto this moving surface. How can I do this? I am pretty sure that what I need to do is project it as a light source but I cant find where I can project animated video. Thanks, Taylor Link to comment Share on other sites More sharing options...
Bugga_Guy Posted December 1, 2005 Share Posted December 1, 2005 make a light over the surface (either direct, or spot light) Goto advance effects and make sure the map checkbox is checked and goto to the "none" button and import a bitmap (your movie in the is case) as you would a normal texture map. make a render and adjust the light parameters to fit onto your surface. Link to comment Share on other sites More sharing options...
William Alexander Posted December 1, 2005 Share Posted December 1, 2005 You might want to check into camera mapping the projection, maybe a more flexible solution, than using a light. Just bit more complicated too WDA Link to comment Share on other sites More sharing options...
tcupp Posted December 2, 2005 Author Share Posted December 2, 2005 Thanks guys I will give both a try and see what I get. And hopefully have a descent animation to post when I am done. Taylor Link to comment Share on other sites More sharing options...
tcupp Posted December 4, 2005 Author Share Posted December 4, 2005 I tried the bitmap projection as a light source and it worked great until I added Radiosity meshing...then it disappeared. I also tried the camera mapping and couldnt get it to work. Any ideas? Taylor Link to comment Share on other sites More sharing options...
