RODRI Posted December 1, 2005 Share Posted December 1, 2005 i need to do realistic grass...i used vray dispacement but i did a sharp grass...unrealistic grass. thank for helps!! Link to comment Share on other sites More sharing options...
lambros Posted December 1, 2005 Share Posted December 1, 2005 If you need very realistic grass for close ups, the best solution would be to use the hair/fur features of max 8 Link to comment Share on other sites More sharing options...
RODRI Posted December 1, 2005 Author Share Posted December 1, 2005 lambros: i don´t have max8 i have max7. i´ll get max 8 soon. thanks for your tip.i try to use onatrix plug in demo but v7 of max doesn´t works... Link to comment Share on other sites More sharing options...
ecastillor Posted December 2, 2005 Share Posted December 2, 2005 I prefer vray displacement...I guess it depends on what textures U R using for difusse and displacement..... Link to comment Share on other sites More sharing options...
alikashan Posted December 3, 2005 Share Posted December 3, 2005 I prefer vray displacement...I guess it depends on what textures U R using for difusse and displacement..... hi i will agree with ecastillor cause vray displacement worked good for me and try changing the diplacemen map you are using it should help. cheers kashan Link to comment Share on other sites More sharing options...
