Mattcantlon Posted December 2, 2005 Share Posted December 2, 2005 I've posted this wip on other forums for C&C but no comments? It's a simple model as I was concerntrating on the lighting\render. Any HDRi techniques or probe link helpful. (Example: I know hdris' don't give strong shadows, any work arounds?) Thanks Matt Link to comment Share on other sites More sharing options...
IC Posted December 2, 2005 Share Posted December 2, 2005 Looks great Matt. Textures are lovely. Simple solution to your shadow problem is to add a weak Area Light. Link to comment Share on other sites More sharing options...
Hector Posted December 2, 2005 Share Posted December 2, 2005 Looks great Matt. Textures are lovely. Simple solution to your shadow problem is to add a weak Area Light. In the same position as the sun in the HDRI image I would add. Link to comment Share on other sites More sharing options...
dbarc Posted December 2, 2005 Share Posted December 2, 2005 It looks good. Maybe play around with depth of field as the render looks pretty crisp all the way through then the HDRI is suddenly very blurry. Can't help you with whether or not you smell I'm afraid.. Link to comment Share on other sites More sharing options...
Tony Posted December 4, 2005 Share Posted December 4, 2005 This is an architectural site. That is probably why your not getting a lot of comments. Try evermotion or CGTalk for more responces on this type of render. Link to comment Share on other sites More sharing options...
William Alexander Posted December 4, 2005 Share Posted December 4, 2005 Very good render. What application are you using? If it's C4D I'd say you "smelled like almonds" (SLA Shaders) WDA Link to comment Share on other sites More sharing options...
Brian Cassil Posted December 5, 2005 Share Posted December 5, 2005 Adding the weak area light to come from the same direction as the sun in your hdri is a good idea, but you may want to exclude the whole scene from recieving light so that it only casts shadows. Link to comment Share on other sites More sharing options...
