carlangas Posted December 3, 2005 Share Posted December 3, 2005 Hi all, I am doing an exterior using an hdri image as an instance in the vray enviroment and in the max background (the one that shows up when you press 8). i do want the hdri to be shown in the glass reflections but dont know how to remove the sky from my final image for compositing. before I used vray and hdri I would just save the final image as a tga file with an alpha channel so when I opened it in ps the sky would be gone. how do i achieve this using vray and an hdri? thanks. Link to comment Share on other sites More sharing options...
ecastillor Posted December 3, 2005 Share Posted December 3, 2005 Why R U using it in the max background? I usually use it in vray's environment AND reflections....save as tga and get as a transparent image.... Link to comment Share on other sites More sharing options...
carlangas Posted December 3, 2005 Author Share Posted December 3, 2005 Why R U using it in the max background? probably because I dont know any better thanks Eduardo, I will use the vray reflection thingie. Link to comment Share on other sites More sharing options...
Tim Saunders Posted December 4, 2005 Share Posted December 4, 2005 and/or, when you save the file check "store alpha channel." then change it in photoshop. Link to comment Share on other sites More sharing options...
