vray fast
only3d
hi all
im looking 4 a way to dramatically decrease the rendering time.
i need 2 create quick previews of the project im working on and its simply impossible 2 wait 20 mts each time!
so any of your ideas will b welcomed
tnx in advance!
I think I remember reading something about using the light cache in both the direct and indirect slots, and it sort of renders progressivly like maxwell, in other words it renders the whole picture with each pass getting better, so it gives you an overall idea of how the final output will look, just stop the render when you've reached a point that you get the info you need...
Don't know if that helps...
1st- tnx 2 those who replied.
illl look in to your tips as soon as i have the chance
2nd- im using the basic settings (irr map for 1st bounce and qmc for 2nd)
and im rendering mostly exteriors.
is there a big difference between ex and in?
Without knowing what version of Vray you are using and having no knowledge of what your settings are it's difficult to say.
but if you have left things at their default state....
In the QMC panel change Adap amt to 1.0 and Noise thresh to 1.0. Fast but ugly.
In the Irrad map panel change the preset to Low.
In the Image Samp. panel use Fixed rate and set to 1.0. Also fast and ugly.
