light cache problems
carlangas
Hi all,
im doing an interior in vray, when I use qmc for the sec. bounce it took about 10hrs to render a view. I later used light cache instead and it took less than 2hrs but it came out black, like theres no gi ussed. dont know what setting im missing beacuse ive used light cache before with no problems.
please help! :(
have you got 'show calc phase' ticked for both irradiance and light cache - this may give you some visual clues..
i do, thats another weird thing. it starts calculating the light cache with all those little dots and it looks like it should not dark like the final image, then the other irr. passes. then the render comes out black.
How about 1st bounce, what did you use? check to make sure you turn on any Vraylight (?). Uncheck "loaf from file" in lightcahce, it probably load previous lightchace file which is empty one. Check to make sure "exposure control" in Max is OFF .
