Guest nazcaLine Posted December 6, 2005 Share Posted December 6, 2005 this issue annoys me: when i want to use batch render in max 8, i get "external file missing". is there a way to tell the program "just render it , no problem a bout the missing maps?" any help would be appreciated, thanks. Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted December 7, 2005 Share Posted December 7, 2005 errr...nobody knows something about this? or is it that nobody uses batch rendering in max 8? Link to comment Share on other sites More sharing options...
ShaunDon Posted December 7, 2005 Share Posted December 7, 2005 Eduardo -- When you say batch rendering, do you mean backburner? If there isn't an option in the General Settings on the manager, try the Advanced button when you submit the job. That's all I can suggest -- you're on discreet's bleeding edge at the moment. Most shops I work with including ours are holding back a couple months before upgrading to 8. Good luck! Shaun Link to comment Share on other sites More sharing options...
BrianKitts Posted December 7, 2005 Share Posted December 7, 2005 I had the same problem with some files doing exactly what you are describing only it was using backburner, instead of batch. My problem was in the switchover from max 7 to 8. Any files that were xref'd in max 7 would fail when loaded in 8. I don't know if there is a better work around..... but I ended up unattaching the xrefs, opening the xref'd files in 8 and resaving them. Then reattaching to the main file in 8. After all this headache, everything worked fine and rendered correctly without any errors. The frustrating part is that the "erroring xrefs" would render fine locally but would error out through backburner. The fix I described above fixed everything though. Like I said I don't know if this is the easiest way to fix what I think you are sharing as the same problem, but it worked for me. Link to comment Share on other sites More sharing options...
abicalho Posted December 7, 2005 Share Posted December 7, 2005 There's no "Don't bother about missing maps" when doing Batch Rendering or Network Rendering. You simply have to get the maps in order. You can click the "Don't show me again" in that dialog, but it's only valid for the current session and outside of batch rendering. Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted December 7, 2005 Share Posted December 7, 2005 abicalho: that's what i was afraid of... i wasn't using backburner (i don't even know what that is:confused: ), only the batch render. but anyway thank you for your replies. yes, i had to find all the missing files and after that everything ok... Link to comment Share on other sites More sharing options...
