mtawheed Posted December 7, 2005 Share Posted December 7, 2005 Hello! I have a scale problem; when I link the cad file to viz using file link manager in either viz render or Autodesk Viz 2006, I don't get the right scale, the dimensions differ, do you any idea why this happens? Link to comment Share on other sites More sharing options...
hussein Posted December 7, 2005 Share Posted December 7, 2005 hello ... first you have to change the unit system in max to any unites you use then when u import or link the DWG file change incoming file units to the same unit as the max . Link to comment Share on other sites More sharing options...
