Fireman Posted December 7, 2005 Share Posted December 7, 2005 Hello friend of cg architect How can i make this "glass" material thx for your help Link to comment Share on other sites More sharing options...
*Pete* Posted December 7, 2005 Share Posted December 7, 2005 do you want to know how to make the glass nearly white and without reflection? im not familiar with 3dsmax, but im sure there is a way to add a gradient on the specular channel, it should give you that effect. Link to comment Share on other sites More sharing options...
ShaunDon Posted December 7, 2005 Share Posted December 7, 2005 Most viz shops do their glass reflections and highlights in Photoshop with passes. Render yourself a specular pass and a pure reflection pass, then composite it onto the render. Try the various blend modes (screen/multiply/overlay/etc) in different layers, and use gradient masks to transitions. I know it sounds like cheating, and it makes animations a bit more work, but the effect is very nice and it's a lot quicker and more satisfying to find the look you want in PS than in max. Shaun Link to comment Share on other sites More sharing options...
nisus Posted December 16, 2005 Share Posted December 16, 2005 Try the various blend modes (screen/multiply/overlay/etc) in different layers, and use gradient masks to transitions. Stick to the normal BM delete a selection on the red channel to make lighter areas reflect less than darker ones ;-)) next do gradients ,-) nisus Link to comment Share on other sites More sharing options...
mitaka Posted December 16, 2005 Share Posted December 16, 2005 The secret is in environment. Use some HDRI! But you have nice glass here Link to comment Share on other sites More sharing options...
