notamondayfan Posted December 9, 2005 Share Posted December 9, 2005 hey guys, doin a standard quick render then this happens the scene has rendered fine b4, and the only thing ive changed is the camera angle. any ideas? Link to comment Share on other sites More sharing options...
JamesTaylor Posted December 9, 2005 Share Posted December 9, 2005 usually get this error when your machine is running out of ram - try reducing the geometry or turning down your settings most noticable the subdivs, finally i think you can tell vray to the HD as virtual ram but it'll slow down your render. i thinkyou turn it on under the vray system panel in the main render dialog box - http://www.cgarchitect.com/vb/showthread.php?t=13667&highlight=dynamic+vray check this post out Link to comment Share on other sites More sharing options...
ShaunDon Posted December 9, 2005 Share Posted December 9, 2005 Hrmmm, over six million polies in trees? Might wanna proxy those bad boys, that will also probably help VRay manage memory. Anything you can do to avoid switching to Dynamic Memory is great as it will save you a lot in render times. Shaun Link to comment Share on other sites More sharing options...
