Problem with windows and doors from ADT to max
Michael-k
I have a little problem with my windows and doors, I have created in ADT.
In ADT and the viz render the windows have a correct materials around the windows frames and the glass. But when I import my dwg file into 3dsmax the whole window is one object, so I cant change the window frame and glass to diffrents materials.
Anyone who knows how to get around this problem ?
I work in ADT 2004 and 3dsmax 7
when you import dwg's in to max, it saves layers/colors (what ever you select as the default) as elements. to select the individual component, click on the window or door, then go to modify>element. You should be able to select the individual component(s) and/or detach them from the larger oject.
hope that helps
