gomantis Posted December 10, 2005 Share Posted December 10, 2005 I'm trying to structure roads so that they follow the path of the terrain. any help would be awesome. Link to comment Share on other sites More sharing options...
theqball Posted December 11, 2005 Share Posted December 11, 2005 this script might do what you want... found on scriptspot.com Wrapper 1.06 Wraps or drapes one mesh (Source) to another (Target). This is just a means of projection that retains the mesh body. Source Mesh vertex heights above Z=0 are transformed to an offset distance from the Target Mesh. Can choose to align the source to the target mesh curvature or have a straight projection. Formerly known as MeshDrape Written by Rab Gordon. Click for homepage. Link to comment Share on other sites More sharing options...
upshot Posted December 13, 2005 Share Posted December 13, 2005 Depending on the level of detail your looking for... sometimes a good ol' bumpmap will do the trick. Link to comment Share on other sites More sharing options...
DareManojlo Posted December 17, 2005 Share Posted December 17, 2005 Hi, Maybe you should try using Conform/Compound object. Also check the help file about details on how to use Conform (even shows a picture of terrain with a road on it ). Link to comment Share on other sites More sharing options...
angelo Posted December 20, 2005 Share Posted December 20, 2005 Gavin, It's been a while, but I think you may want to try the shape merge command. It should give you the option to cut out the road or merge the shape into/onto the terrain. There is a way immediately after the command to save the selection, so you can re-select it in the future for material mapping. Good luck! Angelo Link to comment Share on other sites More sharing options...
RTurner Posted December 29, 2005 Share Posted December 29, 2005 There were a few demonstrations for this at AU this year. All the course outlines are posted on autodesks website. I can send you the PDF if you need. I think they all use shape merge. Link to comment Share on other sites More sharing options...
STRAT Posted December 30, 2005 Share Posted December 30, 2005 shape merge. i draw all my roads in plan, possition them over the terrain in plan, then use shapemerge to make the actual road follow the terrain. Link to comment Share on other sites More sharing options...
bully712 Posted December 30, 2005 Share Posted December 30, 2005 shape merge. i draw all my roads in plan, possition them over the terrain in plan, then use shapemerge to make the actual road follow the terrain. For eye-level, and closeup view, I use this method. For Aerials I render out the site plan in photoshop, and then I use it as a blanket over the mesh. Works very well for me. Link to comment Share on other sites More sharing options...
titoqan Posted January 7, 2006 Share Posted January 7, 2006 I use a plug-in called "Glue Tool" from itoosoft.com and it is free. It takes flat lines and creates 3d lines that follow the surface below it. Take a look and good luck Titoqan Link to comment Share on other sites More sharing options...
