vray reception
The Trickster
looks like you need to up your settings phil, i'd start with the interp samples which should smooth out / blur the motelling effect more as you increase the sample no.'s, obviously this results in the loss of small details too.
otherwise increase the subdivs or irridance map preset, both of which will cause increased render times.
check out spot3d.com for vray help files, it'll give a more precise explanation than my 2 seconds worth!
image looks to have good potential too! post screen shots of your settings and we'll have a look at them
James
Definitely post your settings, but I just wanted to add that I see at least one edge on your curtain wall that's disappearing, so you'll likely want to up your anti-aliasing settings as well to get that back. Assuming this is a full resolution render -- remember if you're rendering at a lower resolution for testing, check a full resolution crop of the area before you increase your settings. It may well not be needed.
Shaun
Thanks guys,
upped the inturp samps which seems to solve my 'dirty walls'
Shaun - will test the AA- but got a feeling its my model!
Settings - http://img216.imageshack.us/img216/3347/settings3lm.jpg
heres another view http://img235.imageshack.us/img235/4659/test0rl.jpg
the two white boxes you see are supposed to be light boxes, but im finding it hard to get a good looking affect - any tips?
Cheers guys!
Just try to understand the material U want to repeat in you 3D model. Has it any refraction? Any reflection? Should they be glossy? Should there be a light emmiter inside?
It is hard to understand for me what material should it be, may be like this one: http://www.dva3.ru/pictures/vis/ani/citydel/13.jpg
or this one:
http://www.dva3.ru/pictures/vis/ani/citydel/15.jpg
