notamondayfan Posted December 19, 2005 Share Posted December 19, 2005 hey guys i was wonderin if ne of u know of ne good tutorials of using controlers to control the rgb colour of objects. im doin a little side project, of a robot, and i want his mouth / teeth to light up when he speaks. jus thought it wud b easier and quicker to set up a controler to the sound of his voice. cheers, deano! Link to comment Share on other sites More sharing options...
notamondayfan Posted December 22, 2005 Author Share Posted December 22, 2005 some 1 must know something..... Link to comment Share on other sites More sharing options...
only3d Posted December 22, 2005 Share Posted December 22, 2005 i think maybe u should try CGTALK.COM here we r much more 'architecture oriented' good luck Link to comment Share on other sites More sharing options...
William Alexander Posted December 22, 2005 Share Posted December 22, 2005 It's really super simple. Make a cube, assign material, open trackview (Graph editors>TrackView). In the tree display find the cube, expand the tree, expand the shader basic paramters node. Diffuse color>right click> assign controller. Just adjusting the color paremeters while in "AutoKey" mode at different frame times will animate the RGB color for you, ie assign a bezier controller by default. The you can edit in edit in the material editor or the curves graph editor..... then again you could assign.... Audio controller for sound activation of colors, or a reactor based on like the upper lip postion...... simplifying the key framing for the Teeth color...that's what your looking to do I'm assuming WDA Link to comment Share on other sites More sharing options...
William Alexander Posted December 22, 2005 Share Posted December 22, 2005 i think maybe u should try CGTALK.COM here we r much more 'architecture oriented' good luck And assigning controllers isn't a good skill to have in architecural animations? hehe Cheers WDA Link to comment Share on other sites More sharing options...
notamondayfan Posted December 23, 2005 Author Share Posted December 23, 2005 cheers m8y! Originally Posted by only i think maybe u should try CGTALK.COM here we r much more 'architecture oriented' also another purpose 4 thing sorta thing cud b club lights, sun, demonstrating fading glass, loads of things Link to comment Share on other sites More sharing options...
