mzex Posted December 19, 2005 Share Posted December 19, 2005 Hi! is possible to convert standard to vray materials? if possible, how? Link to comment Share on other sites More sharing options...
Tim Saunders Posted December 19, 2005 Share Posted December 19, 2005 fraid not. i assume you are wanting to take a material that has some fairly extensive mixes you don't want to "remix?" you can copy the mix itself into a material box, then with the new vray material selected, you can drag the mix you just copied into the diffuse slot in the new material. likewise with allt he other map slots. this saves time. Link to comment Share on other sites More sharing options...
Ray Posted December 19, 2005 Share Posted December 19, 2005 Go to: http://www.scriptspot.com/start.htm search for VrayMtlConverter Link to comment Share on other sites More sharing options...
manta Posted December 20, 2005 Share Posted December 20, 2005 What is the vraymtlwrapper for ? Link to comment Share on other sites More sharing options...
kippu Posted December 20, 2005 Share Posted December 20, 2005 vraymtl wrapper basically helps you control GI properties of that material ... like how much GI it receives and how much it should generate Link to comment Share on other sites More sharing options...
