How to make emitters invisible?
TheAllusionisst
In a simular vien, if you have ever attended a real life photo shoot of a building interior, you would be surprised how many extra lights and reflectors are needed to make the photo look "natural". It's quite an art hiding all this mass of equipment from the camera FOV.
We should have an extensive library of lighting props in the goodies section in the NL forums like Flash umbrellas, reflector cards, gels, barn door lights, and diffusers. Plus downloadable studio lighting setups all ready to grab for that all-important Maxwell 'photo shoot' :p
That's a really good idea.
SketchUp includes a fairly broad set of photo shoot props, though its geared towards moviemaking.
The fact is, making the parts needed to set up a shoot would be fairly easy, and so sharing them would be great.
I've never done photography that way, sowhile I know how to make a camera perform, I do not know the reflectors, lighting rigs, etc.
The basic props are easy enough to make but we'll have to wait for the final materials in Studio before we can make them work as they should to get all the correct properties for diffusers and umbrellas, reflectors are plain old diffuse white and Barnies are normally matt black so that's simple enough. But yes, I really do think that a standard set of photographic props would be universally helpful as they are in the real world.
I'm currently testing a 'ring flash' used for Macro photography to see how well it would work as this is a common item for close-ups. I have it linked to the camers so it's always correctly oriented as the camera moves. It's interesting translating real to virtual in new ways :)
That's a cool selection there. We should convert some of those into .obj or .3ds format which most should be able to import and get a set made for each app that Maxwell works with using common material properties on all platforms. That way we can have complete collections zipped up ready for use. If lightbulbs are added to the lamps then they should be good to go. :)
I've not tried it much, but since MR is using geometry as emitters .....maybe using nano sized emitters could provide some solution. .....but i suppose your probably going to have some pretty sharp shadows with that method. Although, that coupled with skydome or similar could help to counter that.
Dunno, ......maybe it's a stupid thought. But i was thinking about that post Micha started where he was playing a game "Where is the Emitter?" and he used a nano sized emitter hidden i guess basically in plain sight. Clever.
  • 4 years later...
Guys, I haven't read this thread thoroughly and maybe I you already figured it out, but there is a very easy way to make an emitter invisible and hide its reflection, too! You select object - object properties, Maxwell Object Properties - and there you'll find all those check boxes. Explore them!
It's not a problem ... it happens, ..it's funny. thanks.. ;)
Maybe it's good that you mentioned it though, ... because that Maxwell Object Properties Box is probably overlooked by new users -- because they're probably looking for those options in the main plug-in windows.
