Cinema 4d dirt effect
you can use the dirt shader anywhere it's available...totally totally cooool LOL
As part of a mix for the color channel, in the diffusion channel, alpha channel, use it to dim refelctions.....
in a layer shader set to multiply-dirt-fakiosity, in an alpha shder, when it smells like almonds (SLA)........
as a dirt pass and composite at will in post....
the possibilites are endless :)
The most basic uses:
Shader in the color channel- then use rendered image to screen, overlay, multiply.... in PS over the actual full rendered scene.
Same lines no compositing....use it in the diffusion channel, tweak the % & mix values to your liking, super grungy dirt or just a hint of dust LOL
Dirt shader itself....
play with the settings LOL and turn on radiosity
Ray Bias= I leave it alone (RTM)
Distance=distance of spread-reach of dirt
Rays=number of dirt rays cast, more is smoother & longer calc time for dirt
Ray Spread= controls the even spread, 100% linear heavy to light, less than 100% forces a curved response, heavier at the source.
Contrast= Contrast darkers darker & lighter areas brighter
Included an 8.5 file for the image, Happy Holidays
Does that help?
WDA
