lale81 Posted December 26, 2005 Share Posted December 26, 2005 I have a problem with Image Sampler. While I’m using high subdivision the building is losing its sharpness. While I’m using low subdivisions its looks normal, but then glass curtain walls are losing its quality. In this image I used Fixed rate: subd =4 , Building looks soft and the glass curtain walls looks rough. While I used Fixed rate subdivision=6 , glass curtain walls looks well, but then building was too soft. I used other ones they are also makes buildings soft. How I can control it? Pls help. Link to comment Share on other sites More sharing options...
frank1331 Posted December 26, 2005 Share Posted December 26, 2005 I would try changing the anti-alliasing filter you are using. Catmull-Rom and Mitchel-Netravalli work best for exterior renderings. Also, I would use an adaptive subdivision for the Vray anti alliasing. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted December 26, 2005 Share Posted December 26, 2005 Are you using a brick texture on your building? Also what resolution are you rendering at? Link to comment Share on other sites More sharing options...
pradipta Posted December 26, 2005 Share Posted December 26, 2005 image is too small, can you post a bigger render? i think the problem lies somewhere with the filter Link to comment Share on other sites More sharing options...
lale81 Posted December 27, 2005 Author Share Posted December 27, 2005 I would try changing the anti-alliasing filter you are using. Catmull-Rom and Mitchel-Netravalli work best for exterior renderings. Also, I would use an adaptive subdivision for the Vray anti alliasing. Thanks. But I used here Catmull Rom, but it lost its sharpness, because of fixed rate sub.=4. In this image I used: 1. very high GI 2. Fixed rate=4, Rand 3. Object outline 4. G-Buffer=1.3 5. Enviroment 6. QMC Sampler amount=0.1, noise threshold=0,001 Link to comment Share on other sites More sharing options...
lale81 Posted December 27, 2005 Author Share Posted December 27, 2005 image is too small, can you post a bigger render? i think the problem lies somewhere with the filter 1-st image I used here Cartmol rol, but it lost its sharpness, because of fixed rate sub.=4. In 1-st image I used: 1. very high GI 2. Fixed rate=4, Rand 3. Object outline 4. G-Buffer=1.3 5. Enviroment 6. QMC Sampler amount=0.1, noise threshold=0,001 7. Filter = Catmull-Rom In 2-nd image I used: 1. very high GI 2. Adaptive subdivision min rate =0, max rate=3 Threshold=0.001, Multipass 3. Object outline 4. G-Buffer=1.3 5. Enviroment Link to comment Share on other sites More sharing options...
lale81 Posted December 27, 2005 Author Share Posted December 27, 2005 Are you using a brick texture on your building? Also what resolution are you rendering at? It isn't brick texture. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted December 27, 2005 Share Posted December 27, 2005 I still can't really tell whats going on because the images are so small. Can you post larger images? I can take a look at the file for you if you upload it somewhere or e-mail it to me. Craig Link to comment Share on other sites More sharing options...
