Guest eddie57 Posted December 27, 2005 Share Posted December 27, 2005 I am a novice autocad user and I have a drawing that was draw in in the scale of 1/4 = 1'. I scaled it to half it's size so I could print it on a smaller size paper at a scale of 1/8"=1', but now the dimensions are half the size. for example if the room was 12' by 12' now the dimensions say 6' x 6'. How can I get the dimensions back to original while having the drawing at half the size? I know I can create a block and do it that way, but I would like to be able to have the drawing accessible to changes if need be. Thanks Eddie PS: I am usings ADT Release Link to comment Share on other sites More sharing options...
mbowers Posted December 27, 2005 Share Posted December 27, 2005 Eddie, Are you using paper or model space? Scaling the drawing down in model space would be a bad idea, i would simply create a paperspace drawing layout and then change the scale in the viewport, everything stays the same, but the scale is smaller to fit onto the desired sheet size. Hope this helps. Link to comment Share on other sites More sharing options...
RAYMOND Posted December 27, 2005 Share Posted December 27, 2005 also, just create another dim style for different scales. but ditto on the do the setup in PS... btw, don't dim in PS Link to comment Share on other sites More sharing options...
Guest eddie57 Posted December 27, 2005 Share Posted December 27, 2005 Thanks guys, never worked with paper space. I know I should be. Will be asking questions. I try that dimension style with a different scale. Thanks again. Eddie Link to comment Share on other sites More sharing options...
Fernando Lino Posted December 28, 2005 Share Posted December 28, 2005 I always use paper space...and I customized my dimension style, I only use one style, when I change the scale (under setup settings) my dimension size also change. In your case make it a block and scale it. In the future I recommend you paper space...easier for you and your consultants. good luck Link to comment Share on other sites More sharing options...
